  • Own an LG TV or webOS device? Join our Forum!
    Register now to gain access to our webOS user support forum. Once registered and logged in, you will be able to post a user to user support request topic to this site or reply to existing topics posted by other users. You can also take part in our other webOS user forums. You'll be able to customize your profile, receive reputation points, while also communicating with other members via your own private inbox, plus much more!
Yes, via usb. It is described at the download page from LG next to the firmware in a document. Create an LG_DTV folder on a usb drive and put the unzipped firmware in it. Put it in the tv and click the popuo and pull it out only when it is ready updating.
Share this post
Link to post
Share on other sites
Well I took the plunge last night and installed the latest software. Fingers crossed all OK. Again I can not be bothered to reset to default, when will LG give us a backup
settings option or app to make it easier to restore picture & sound settings after re-install or new firmware.
Share this post
Link to post
Hey guys. As I just learned from the LG chat on their website, they do not publish changelogs for their firmware updates. Downgrades are also not supported. So, crossing fingers and hoping that things don't get worse is all some can do? :-(
I am not sure if I want to upgrade to 05.05.01 on my 55EC930v . Are there any drawbacks known so far?
Share this post
Link to post
I did the upgrade on my 55ec930v and did not find any drawback but no improvements either. I came from a beta 05.00.55 and wanted to have the official release. There also was an official 05.00.55 but I could not install it because it was no newer version.
Share this post
Link to post
After upgrade I cannot log to my account anymore. It says that service is not temperary available. Anyone with same problem ?
Sent from my SHV-E160L using Tapatalk
I have the same account problem, also unable to open the LG store to get apps. Mladjokis have you made a full reset after the install?. I haven't and don't want to because I may loose all my app and will not be able to download them.
Share this post
Link to post
No after turning off and on again everything works again.
Share this post
Link to post
Oh well, looks like I may have to do a full reset & start all over again with settings. Just hope I can log in and download my preferred apps from the store.
Share this post
Link to post
upgraded from 03.10.60 to version 03.15.02 on my TV 49UF640V this morning, didn't see anything new.
Any changelog ?
did someone know what means the fistr two digits : 05.xx.xx, 04.xx.xx or 03.xx.xx ?
Share this post
Link to post
Does anyone want to share their findings about firmware 05.05.01?
I noticed one odd thing after a few weeks with 05.05.01 on the LG 47LB671v... I happened two times now that I got a message from the TV saying (in German): "The TV will be switched off in 5 minutes" ... and NO, I did not use the timer function of the TV EVER... I waited to see if this was a "freak"  message but after 45 minutes the TV really switched off. Very strange, will watch this behaviour closely.
Anyone else had this?
K.
Share this post
Link to post
Are these firmware's model specific?
Absolutely! You can't use a firmware for the LB6xx series for the UF models. Fortunately the firmware update process checks if the firmware is suitable for your model and refuses to update to an invalid version.
K.
Share this post
Link to post
K.
How many time without using the remote? Maybe it's the powersave feature
Enviado desde mi ifive_mini_3GS mediante Tapatalk
Share this post
Link to post
Any changelog ?
Now in 03.15.05, automatic update.
Share this post
Link to post
Hy to all
I follow this topic once or twice a week and I didn't post for a long time so I din now.
I see on the last update 05.05.01 for 2014 models, in browser, don't show anymore the memory error message if I browse no more then 2 or 3 pages at a time (one with streaming). Maybe they did a good job with the memory management.
Share this post
Link to post
    • By AspieMum
      I installed a few apps trying to get Casting to work that didn't work properly and I can't find anyway to uninstall them. My TV doesn't seem to have edit mode perhaps because I have had it a few years (pre-2018 some when- possibly its 10 years old or more as I can't remember when I got it). Anyone know how I can uninstall them?
    • By invinci
      Hello Everyone,
      I have 2014 LG 47LB750T tv and I am happy with the TVs performance. It has just updated to newer 05.05.25 firmware. New apps are getting added in the store.
      I have been following HotStar app in my phone from quite a long time. It has a very good list of shows and movies list. I was wondering if we can have HotStar app for our WebOS tv as well. Recently DittoTV app has too been added which is a boon for those who have frequent DTH cable connection problem. It directly streams live over the Internet and package is very economical.
      If LG Developers can also introduce HotStar app for our LG TV it will be a big boost to the platform as it is very popular in India. They also have their own Original series just like Netflix which are also very good. So requesting devs to kindly introduce HotStar app for our WebOS TVs. Thank You.
      Link to the HotStar website:
    • By kimbovk1984
      hola buenas tengo un televisor lg webos tv oled55b7v y la imagen y los colores no se ven bien necesito ,alguien que me espricase como configurar
    • By Rineeth G
      Dear LG team
      How to get SONYLIV AND VOOT KIDS app in LG store to install in my LG webos TV
    • By luis santos
      Change to android
    • By buckda
      After update, sound and picture is gittering.. picture jumps and sound goes quite then very loud every second. Can I reverse the update
      this occurs on TV, Netflix, and Prime,  so it is not an app issue..
      how can I fix this.  Turning tv on and off does nothing
    • By Jeroen Jansen
      Hi all,
      hope someone can help me. I have a LG 49LX761H model 2016. I know it’s a hospitality tv but turned that mode off it works perfect. We upgrade the webos to the latest version available but the content store is not available. Is this function not available on this model or do I need to turn something on. Hope someone has the answer. Thanks
    • By sharathks00
      I have
      LG webOS TV UF950T,
      software version 04.06.00
      1.)  WebOS is getting updates but new  apps are not showing up in LG  Content store.  When I visit
      link hidden, please login to viewthrough my Tv browser there are many new Apps which are not in LG content store.         When i try to install , it says  not compatible with your Tv. 2) When i try to play a video some times it says video format not supported and some times audio format not supported like with opus & ogg.
      My question is to Manufacturers/ WebOs designers if this is the case what is the point in updating TV, when there are no apps or support for new video or audio formats ????
      In this case its like if i want new apps, I have to buy a new TV, updates are not helping in improving TV in any ways, no longer a Smart TV
      lol
    • By Kirtan Mehta
      Hi,  I need help to open Microsoft Teams on my LG Webos TV..
      I have LG WebOS TV OLED55C8PTA. My software version is 5.10.45.
      When I open Microsoft Teams browser version from the browser on TV, I get the error message that "Hmm. Your browser version isn't supported. Here's what works: Microsoft Edge, Google Chrome, Mozilla Firefox."
