WebOS TV Firmware version
By quentar82
In the specifications of this LaserTV it is shown that WebOS 6.0 should be installed on this device.
The latest Device Firmware Version is 3.01.02 and i am missing the RTL+ App (Germany) which should be available with WebOS 6.0
So any info when there will be a "real" WebOS 6.0 available on the Cinebeam HU915EQE?
By dolbnya
By nkat
Hello Team,
I'm unable to play any video any video on LG TV WebOS browswer.
I've tried to play
link hidden, please login to viewm also, but no luck. I've toggled (on and off) the 'Adpative Javascript video stream' settings in browser but no luck.
Can any one help on this .?
By Roy Brown
By SailorMoon
- 1 reply
- 1,538 views
- 8 replies
- 33,346 views
- 1,910 views
- 1 reply
- 3,658 views
