  • Own an LG TV or webOS device? Join our Forum!
    Register now to gain access to our webOS user support forum. Once registered and logged in, you will be able to post a user to user support request topic to this site or reply to existing topics posted by other users. You can also take part in our other webOS user forums. You'll be able to customize your profile, receive reputation points, while also communicating with other members via your own private inbox, plus much more!
On 7/31/2014 at 2:46 AM, majorusa said:
- 3.23.24 - Romania- 47LB730v
Share this post
Link to post
Share on other sites
On 26/10/2017 at 2:50 PM, Alessio1989 said:
43" 43UJ750V, updated today  to 04.70.06 (04.70.10 available on the support site), Italy.
Notes: looks like no major improvements at all for 2017 LCD models, no major bug fixed (no FLAC from PC/server play), got only an update for the YouTube application.
43uj750V updated to 04.70.30. No release notes yet available.
EDIT:
Quote
[04.70.30]
1. To improve Youtube VP9 HDR Contents SDR processing issue
2. To improve Smart Retune Deleted Reservations issue
3. To improve OLED Model Screen Saver occurrence issue
4. To improve issue of canceling favorite setting channel in European Standby Channel Update
Share this post
Link to post
Does anyone know any firmware link below 05.05.25 for the 47 LB6500. I need to downgrade because I had problems with the upgrade, since I had downgraded with a firmware different from my model and when I upgraded with the correct epk I can not tune the HDTV channels anymore. A colleague said that it would suffice for me to install the atsc firmware that would re-tune the HTDV channels, but even with the correct firmware upgrade it is not tuning.Thank you in advance for your cooperation.
Share this post
Link to post
I've downloaded 04.70.65 from LG and copied ZIP file to USB, unpacked it and connected USB to TV but nothing happens.
TV recognises  USB is inserted but just wants to play media files from it which don't exist.
The OS update option in the TV settings seems only to look for updates over the internet, not from a connected USB.
Any help out there?
UPDATE : Since found out, needed to create a folder on USB called “LG_DTV" and put the file in there.
Share this post
Link to post
Any help out there?
1. Format usb flash with fat32
2. Create folder LG_DTV on usb flash
3. Copy  .epk file to this folder
4. Safely eject usb
5. Connect usb flash to TV
6. Confirm usb update and wait 5-10 minutes
7. After sucessfuly update popup notification show on tv screen now you can restart tv(turn off/on)
8. Reset to factory settings after start for best performance
9. Enjoy in new firmware
  • Thanks 1
Share this post
Link to post
I had the information that my LG's WebOS (Greece 1.4.1, 42LB650) can be upgraded to 2.0
Is that so? How? I can not get into LG Greece site although I have been registered there  too... Pls help
Share this post
Link to post
New firmware update for LB630-LB870, EC930 (webOS 1.0)
Europe models only!
Create LG_DTV folder on formated flash usb memory and copy .epk file
05.05.55
Download:
http://su.lge.com/GlobalSWDownloadCdn.laf?IMG=/201804/starfish-dvb-secured-m14tv-25.ashley.m14tv-2529-05.05.55-prodkey_nsu_V3_SECURED.epk
Source:
http://webos-forums.ru/topic4244.html
Share this post
Link to post
Europe models only!
05.05.55
Download:
Source:
Anyone tried this firmware ?
Sent from my SM-J510FN using Tapatalk
Share this post
Link to post
The really interesting question for me is: are there any visible or noticable changes/improvements in this version when upgrading from 05.05.45  ? Unfortunately there is no changelog (as always, shame on you LG...) so we have to rely  on user reports... Thanks!
Share this post
Link to post
14 hours ago, Dejan Fehirov said:
HI Dejan,  long time no speak😉. How is the new firmware holding up, any noticeable differences? or pretty much same same.
Share this post
Link to post
 Release History on model 42 LB 730 V
[04.45.25] from 05.2015
1. Apply HEVC at UK, Czech, Spain, Poland
2. Apply HbbTV default On at Estonia
3. Apply setting UA field in Browser by SDP Server
4. Apply code page auto detect on UTF8/UTF16 at Subtitle
5. Delete upcoming contents at Today
6. Timezone in Russia
7. Fix Satellite searching issue in Spain
[05.00.15] from 10.2015
1. After Value Pack SU, Problem is fixed.
Problem: Simplink On, connect set-top > Out Of Memory PopUp > Reboot TV This
[05.00.40] from 12.2015
1. High frequency noise problem improve in EC93 OLED model.
[05.00.55] from 12.2015
1. Improve the OLED compensation error
[05.00.60]
1. Apply the DTV 7/8Mhz frequency
[05.05.01] from 05.2016
1. Improve video stop issue in Live Contents of Premium Online.(Italy)
2. Improve the MHP’s no working with HbbTV & MHP stream.
3. Improve the Tricolor satellite channel missing issue. (Russia)
4. Improve the Digiturk (Turksat) fast scan’s no working.(Turkey)
5. Improve the Filbox fast scan’s no working. (Turkey)
6. Improve the Canal Digital EPG’s no working.
[05.05.20] from 10.2016
1. Change the OTAU SO satellite (Intelsat904 to Kazsat3) - Kazakhstan
2. Apply the DVB-T2 system - Czech
[05.05.35]  from 10.2016
1. Disable the skype due to spec out.
2. Improve the Tricolor satellite channel crash - Russia
[05.05.55] from 04.2018
1. Minor Bug Fix
Here is the link from LG Romania usb update:
http://gscs-b2c.lge.com/downloadFile?fileId=M36LIcfJd3YUOCr6z7SOQg
I noticed a 16 MB difference between NSU and USB version, I have both.
  • Thanks 1
Share this post
Link to post
I installed this new firmware and everything is seems to be fine. No problems at all..
If you like my work you can donate me if you wish https://www.paypal.me/DejanFehirov/3
Share this post
Link to post
Wow, I've never seen such a changelog from LG, where did you find it? Thanks Mate!
Share this post
Link to post
    • [pivotCE]Two Palm Foleos available on eBay – cheap!
      First, no this is not my auction nor do I or pivotCE know the seller in any way! This crazy deal is just too good NOT to tell you about. Every once in a while a Palm Foleo pops up on eBay with a price tag to match its rareness…usually around $1000 USD (or $2300 like the New in the Box one there right now)! But these? A paltry $179 and $11.65 in shipping (only to the USA though) and that’s the Buy It Now price. You can make an offer and possibly get one or both of them for less. For the PalmO
      in pivotCE News
    • PreCentral: Export your contacts via Command Line (homebrew)
      You always want to make sure that you have a backup of your critical data that you keep on your smartphone or tablet, and your contact list should be towards the top of your priority list when to comes to ensuring you have recent backup. If you use cloud-based synergy accounts for your contacts like Google Contacts, Facebook or Yahoo, you are probably less worried about having a backup since you can always go back to the source data and pull it down again. But if you use the Palm Profile or a di
      in webOS News
    • PreCentral: PSA: TouchPad cases dirt cheap!
      So you're a TouchPad owner. Maybe you purchased it full price or maybe you waited until the now legendary fire-sale of the TouchPad after good ol' Leo Apotheker killed webOS hardware. You might even be one of the hardcore webOS users that paid top dollar for a beautiful white 1.5GHz  TouchPad with a whopping 64GB of storage! Regardless of how you got your hands on one or how much coin you dropped on it you love your TouchPad all the same. Because you love your TouchPad you want to protect it wit
      in webOS News
    • webOSroundup: webOS CTO, Sam Greenblatt is out, no one next in line yet
      The folks at webOS Nation have reported that Sam Greenblatt has left his post as webOS CTO and will no longer be in charge of webOS. After reaching out to HP they also received confirmation with the following comment: “Sam Greenblatt is moving from webOS to a new role at HP and will continue to assist the team during the transition. The Open webOS project is on schedule and HP remains committed to the roadmap announced in January.” Currently, there is no indication as to who may be next to t
      in webOS News
    • PreCentral: Fast, good, or cheap - or why you can't build a smartphone
      Every other week or so a new thread pops up in the webOS Nation Forums about the possibility of building our own webOS smartphones or tablets. It always seems to garner a bit of attention, especially when the poster comes in with a set of state-of-the-art (or beyond) specs for their phone that they may as well have lifted out of the latest and greatest Android handset. While this kind of thinking can be fun, I'm here today to dump a bucket of cold water all over it. Today's smartphones are incr
      in webOS News
    • By ahmed bimo
      My smart TV model : 42Lb6520
      WebOS: 1.4.0-2532
      Issue: many applications don't exist in LG app store like shahid despite the importance of this app that the most famous app in the middle East
      And any other applications like Spotify and starzplay despite the importance of that
      Please add this applications to LG app store
      Thanks 😊
    • By Zedric
      After purchase my LG smart tv was able to pick up DTT (digital Terrestial Transmitters in the local area. These channels failed to work after some time and it was assumed that they were switched off due to the never ending wait for South Africa to migrate fully to digital.
      However tuning my sons Hi Sense tv the said channels were found and indeed are operational as  digital HD channels
      Returning to my LG tv i changed the location to digital , retuned and lo and behold the digital channels appeared on a multiplex on uhf  channel 49 (8mhz) however within a few minutes they disappeared never to be seen again isn spite of much time and many alternative settings.
      I have tried changing location, adding  channel 49 UHF manually which shows full signal strength and quality, but gives no digital programmes found.
      I have had to revert to the 4 terrestial channels to get any tv operation at all.
      I believe that my set has been crippled by LG. I am highly upset considering the cost of a uhd TV thats not capable of performing ito its original specification or  at its best.
      Any advice on how to obtain a working system ( frimware has been updated ) or the legal route to go to resolve this issue would be welcome.
      NB as a retired broadcast technologist i do have some knowledge of the industry so would welcome any technical perspectives if i have missed something
      thanks Mikei
    • By 51.sqn
      Hi All,
      Has anyone had a recent update of the OS on their TV to 4.7.050204 (goldilocks2-gulaga) ?
      The reason I ask is that the IPTV channels on my TV seem to have borked these channels as I now get "Invalid Service"
      floating across the screen. I'm pretty sure these channels worked before the update.
      I'm referring to channels such as Now 90's, Planect Knowledge, The Sports Channel Network etc. So these are NOT APPS but
      TV Channels showing up on the guide and still show the programme details.
      This TV is only a week old, and I think I'm going to be bounced between the retailer and LG as it seems to be a software issue.
      Does anyone have similar experiences and have you resolved the issue ?
      TIA
      51.sqn
    • By Questor
      Question: Why does LG's website say I should check this forum to see if 3rd Party Bluetooth Headsets with work completely and correctly with LG sound sync and WebOS, when LG has not or will not publish a list of which 3rd Party Bluetooth Headsets are tested as compatible with specific LG TV models?
      We recently purchased an LG 55UM7300PUA (2019) TV and have a question about which 3rd Party Bluetooth Headsets that are compatible with LG sound sync and WebOS...  My wife wants to listen to our 55UM7300PUA TV through a set of Bluetooth Headphones while the TV Internal Speakers are turned off...
      It seems that LG's USA website needs to be updated because LG's search results about our 55UM7300PUA model seem incomplete. The LG Tech Support website does not list the 55UM7300PUA as a TV nor Smart TV product and no 55UM7300PUA or 55UM73 manual is listed in search results.   I finally found the Owners Manual for our 55UM7300PUA through a Google search, but this PDF Owners Manual I downloaded does not say if our 55UM7300PUA supports LG sound sync or which manufacturer/models of Bluetooth Headsets .
      I am disappointed by a lack of technical support from LG in past forum discussions regarding which 3rd Party Bluetooth Headsets with work completely and correctly with LG sound sync and WebOS.  LG Technical Support is forcing customers like me to buy Bluetooth Headsets at our expense, they ask us to do their testing with a lack of specific 55UM7300PUA documentation, and they direct us to "refer to headset model names in user guide" that are not simply listed.
      Does our 55UM7300PUA support the use of Bluetooth Headphones and is "LG sound sync" required for use with Bluetooth Headphones?  Why should we have to test 3rd party Headsets at our expense when LG Tech Support should specifiy which OEM and 3rd party Headsets work with which LG TV models?
