[pivotCE] Skype is likely on the chopping block…again
pivotCE
skype_webos.jpgWe first told you about Skype support ending for webOS back in
. Much to our surprise within 6 months.
But here we are again, right on the cusp of another synergy service waning in the golden years of webOS.
that pretty much anything older than Windows 8.1 Mobile will no longer have Skype support. And really that’s my interpretation since the article only mentions Windows 8 which was in fact different than 8.1. Their new infrastructure is based on the cloud and will move away from peer-to-peer. Why the change?
“Because of the transition to the cloud, Skype is having to leave some older, legacy devices and platforms behind:
The pace of change in our industry means that the devices and operating systems used by the majority of people shifts with time. Our commitment to deliver the best possible cross-platform experiences requires that we continually assess when it’s time to increase our focus on the platforms of the future. Sometimes this means that we must end support for some devices and operating systems.”
Not everything is being abandoned though.
“Skype says they will continue to support Windows 7, 8, XP and Vista, Yosemite on Mac, iOS 8 and Android 4.03 operating systems, and obviously Windows 10 and Windows 10 Mobile. So if you’re using a relatively new operating system, you’re good to go.”
So we’ll see what happens. I’ll hold off on playing Taps just yet.
#webOSforever
Related posts:
Link to comment
Share on other sites
    • By pivotCE
      Picture credit: from Pixabay
    • By pivotCE
      The webOS community may be a bit smaller these days but it’s no less devoted to the platform. WebOS Ports is a small team of developers. As you can imagine, it is a few people to maintain a full OS that consists of thousands of components. Things are starting to come together for LuneOS, with the current major rebase and stable release. But we still need your help.
      As nice as it is to have some additional folk contributing, developing, and working on issues, we still need more developers to get involved to make this community project really take off.
      “Our focus is core functionality”
      We cannot stress enough that we are building an OS focused on core app integration that is simple, beautiful, and user-centric. Right now, function comes first. If we had a penny for every developer that knew some web code and could make a beautiful static mock-up of an app that didn’t do a thing in the backend and then said “I did my part, it’s up to you to make it work”…well, we’d have a lot of pennies.
      Developer requirements
      Once core app integration happens we will need HTML/CSS smart people. But to be an asset to the team, you need to have a good grasp on any or all of these technologies:
      Javascript C node.js C++ QML Qt Yocto Graphics design Are you decent at some of these, but might need help from time to time? That’s fine!  We’re a community, remember?  Hit up the
      link hidden, please login to view and/or channel and ask! Get the bugs out!
      We have several applications already available but many are placeholders or have basic functionality. Some of the apps are almost fully functional like Settings. But even Settings has bugs and can use refinement.  OK there are bugs everywhere! (If only it were as easy as a can of Raid to fix them)!  We’ve received lots of questions about how to get plugged into the project quickly.  Easy! Head over to our  to see current issues. Find an area where you think you can help and then find us on or (see below) to talk about it.
      Some examples of areas that need bug fixing are:
      Email: Some minor bug fixes Settings: Add Settings when needed Phone: Further polishing Calendar: Google C+Dav integration needs updating to adopt for Google’s changes Browser: Rework UI to be more webOS/LuneOS like And more. Core Apps/Features/Backend magic
      The Open webOS project released several core applications that were Enyo1 based.  These apps are in LuneOS
      Messaging: Needs a rework or rewrite to give proper functionality similar to legacy webOS PDF needs converting to QML. LuneOS also needs a media player app (maybe reuse/rework the webOS OSE app for this?). The C+Dav connector is there, but it needs updating for various changes by Google. It also needs testing for other providers. Additional IM connectors would be good to implement (Telegram, Signal) etc, there are existing plugins exist for Pidgin/libpurple that can be used. Looks aren’t everything
      As you can see, to really make stuff work first, most of what we need is in the backend.  It’s the old battle between form and function. Which comes first?  Designers will argue form!  But Ports is focused on the core functionality that has to work first and look pretty later. It’s a hard pill to swallow and we get that, but when building an OS, it’s the most important thing. If it looks pretty but doesn’t work, the project loses potential users. If it works but doesn’t look pretty it will at least show promise and that encourages positive feedback. And with a community led project, if you don’t have good feedback you’ve already lost.
      Additional help wanted
      Ports is looking to expand our public relations presence. If you are located outside of the United States or more specifically speak a different language than English and would like to help us advertise and direct interested people toward LuneOS and WebOS Ports, please let us know.
      We are also looking for a WordPress “expert” for a new site we’ll be setting up soon. Are you good at making tutorials?
      We have several “How to install LuneOS guides” on the wiki. If you’d like to make friendly guides, that’d be great!
      And finally, we need a “wiki-meister”. Someone that really knows the ins and outs of running a mediawiki!
      Get involved
      Everyone can help in some way. We need testers and bug reports! Sign up on the , contact us to let us know that you signed up and what your username is, and we’ll upgrade your account so you can post issues.
      Developers please join us on and/or drop by the IRC channel
      How to Contact WebOS Ports
      Want to get involved? Have a question? Get in touch with us.
      [email protected]
      Twitter:
      IRC (Libera):
      Telegram:
      Issue Tracker:
       User Support Forums
      Join the forum .
    • By pivotCE
      Have you been wondering what LG will do with webOS next?
      According to
      link hidden, please login to view, a since pulled website has arisen (here are the cached pages from Google  and ) detailing info about LG’s all new platform supposedly called ““. It is thought that this is going to rival Samsung’s Tizen, maybe even in retaliation to Apple’s new smart watch. Hopefully our loyal fan-base will make it popular! According to pictures pulled from the site (see below), the SDK for the said smart watches, will supposedly be released with the announcement of LG’s plans to move webOS to the Smart watch platform. To see the other banners pulled from the site click
    • By pivotCE
      It appears Future Publishing US have decided to “Sunset” the WebOS Nation forums. This term could mean anything from ceasing product support, through archiving to full closure. Whatever the term means in this case, the process is due to begin in early January.
      pivotCE was originally created some years ago to fill the gap in webOS news when
      link hidden, please login to view stopped publishing stories, but the forums continued until this day. Many of pivotCE’s stories were originally sourced from the forum. Both parts of webOS Nation contain a wealth of data and history about the webOS project and it’s successors. It’s hoped that this information can be preserved in some way. If you have a comment or can offer help, .
      You may want to consider joining the discord instance at the .
    • By m571
      It would be nice if we could be able to use any usb hd camera.
