By tomatowarden
Hey everyone, I've been using my LG WebOS TV for some time now, and there's a small but impactful change I'd love to see. Currently, when the TV is turned on without an HDMI input, it defaults to displaying a wallpaper. It's not aesthetically pleasing, it's a bit of an inconvenience for users like me who primarily use the TV's smart features.My suggestion is to include an option that allows the TV to boot directly into the Home screen, displaying all the available apps and streaming options right away. This would streamline the user experience, making it faster and easier to access the services we use most.Would love to hear the community's thoughts on this. Cheers!
By SailorMoon
By Akshay007
Altt Balaji application is not available in the App Store of the LG WebOS TV 43UQ8040PSB model. Please could you help me find the app or any alternative way to install this application.
Appreciate for your help thanks.
By Monsieurto
I have a TV, brand is not LG but firmware is WebOS Hub 2.0 and webos version is 7.3.2.
Can I upgrade WebOS Hub 2.0 to 2.0S? Thank you.
By Musica napoli live e anteprime
Hi, I would like to know if it is possible to exceed a speed of 100 mb/s with an Ethernet adapter for LG webos 3.5 TV and if so which adapter? I tried the one from Cable Matters but nothing
- 1 reply
- 1,489 views
- 8 replies
- 33,175 views
- 1,894 views
- 1 reply
- 3,536 views
