WebOS TV Firmware version
  • 1 month later...
On 7/28/2021 at 8:22 AM, Mcgyver83 said:
Hi, I have an 43LF590V (Italy).
A couple of apps I was using are now dismissed.
I red a lot of post saying "firmware update" in this thread.
Does LG WebOS updates fits also for my smart TV?
Hai trovato qualcosa ?
Link to comment
Share on other sites
On 04/08/2014 at 08:26, MrNorth said:
Connaissons-nous la différence entre 3.2 et 4.0 ? Peut-être s'agit-il simplement de fonctionnalités localisées telles que « aujourd'hui » ? Je n'ai aucune idée des politiques de version de LG, mais un changement majeur de 3 à 4 suggérerait dans mon monde une refonte majeure, plusieurs nouvelles fonctionnalités, etc.
N'y a-t-il AUCUN moyen d'obtenir un journal des modifications ?
/H
Moi j'ai un model UR80 50" une nouvelle misajour s'affiche version 03.20.55 et j'ai peur de la télécharger a cause des problèmes que j'ai lu sur les forums
Link to comment
    • By dolbnya
    • By nkat
      Hello Team,
      I'm unable to play any video  any video on LG TV WebOS browswer.
      I've tried to play
      link hidden, please login to viewm also, but no luck. I've toggled (on and off) the 'Adpative Javascript video stream' settings in browser but no luck.
      Can any one help on this .?
    • By SailorMoon
    • By pivotCE
      link hidden, please login to view hold a number of events. This year’s will be of interest to fans of webOS phones, tablets and other computing devices of the past. The festival is held at the and runs over three days from the 12th to 14th of April. The festival includes three elements:
      – some with modifications to function in the modern environment. and . . For readers of this blog, representation of webOS devices will be in two of those areas. Jon W of the is attending over the weekend and will give a 50 minute talk at 900am on Saturday the 13th. The consignment shop will have a small selection of webOS devices for those who are interested.
      So if you are in the area, why not go along?
      If you can’t make it, you can follow along via the and TouchPads are available remotely at
      Discussion is at the . You can read more .
      Picture Credit: .
