PreCentral: Arthur Thornton heading to an HP internship… again
By Calvinder
Any suggestions
By Samreen Singh
I am facing this issue after updating to the latest version of firmware. On my Wifi, I am not able to install/ update any app. Error is coming as written in the title of this post. But when I am using mobile hotspot everythings fine. I have tried all options resetting my router to factory reset, resetting TV, dns setting change to 8.8.8.8. but nothing is working for me for my Wifi.
My tv model is LGUP7500PTZ pls help
By jikhead
I'm not getting any audio from the apps via the HDMI via ARC connection to my receiver. This occurred two weeks ago and was unable to resolve it, but ironically there was new firmware released that same day for my B6 (3/31/17) and this fixed the issue. However, now I again can't get it working after a TV reset and tinkering with the audio settings again. I tried to load the firmware again, but it appears this is not possible to forceable load the same firmware.
By SNiPpy YiPpy
Hello all,
I believe this problem started after i accidently started and immediately cancelled the download of a app. After this I am unable to install or update any app evem after resetting to initial settings.
This should be the exact problem found here https://www.lgwebos.com/topic/1918-because-i-can however the solution seems to require a new update. Help?
By dennik
I have a problem updating or installing amazon prime video app. When hitting the update button (after several factory resets) it simply says "Application has not been installed. Try again" after it stops.
This possibly happened due to a cancelled update a week ago.
Any ideas how to fix this? Factory reset doesn't work. App won't run without update, and update won't run.
